Outcast v1 body should fit. The v1 used the same chassis as the Granite.Outcast v1 probably too big as well. Granite chassis is super short. Probably could find a nice proline body. Anything for stampede or granite will work.
Granite and outcast v1 use the same chassi. You'll need f/b body post to make the outcast body fit.Outcast v1 probably too big as well. Granite chassis is super short. Probably could find a nice proline body. Anything for stampede or granite will work.
Granite chassis
center drive shaft
everything else should swap right over. Outcast body will not fit on the short granite.
The Granite and Outcast use different lengh body posts. Outcast are longer and fod flexible than the Granite.Outcast v1 probably too big as well. Granite chassis is super short. Probably could find a nice proline body. Anything for stampede or granite will work.
