You will want and need a
4s ESC/Motor setup. The limit at 99% of Tracks is 4s packs.
Leave the TLRT in stock setup config at first. And learn to drive it as is. The TLRT manual is very clear with setup and explaining the Pill changes etc. Start reading it more. Buy
Tires that most are using at your track. Ask there first!!
I know for sure the Included stocker tries will be NG. Promise. They are too hard to begin with.
Try for yourself on the track and you will see what I mean
I run an XR8 Plus HW, 2250kv 6s combo. And with 4s Race packs only . But you use can a better, lighter setup. You want to keep the chassis light. It's a bit heavier than most Track Race Kit built models like from TA and Losi and Tekno.
Be very careful with adding too much in Bling alloy, if you can avoid the temptation. Just adds more weight.
CF Towers are one good option down the road. Lightening it more. Lowering the C of G.
Look at the HW XR8
Pro Sensored combos.
Sensored setups are best for a techncial track setting.
Have fun at the track.
