Arrma V3 shocks, boots twisted
JMS RC
Sweden
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Kraton EXB
  5. Nero
  6. Outcast 6s
  7. Talion
  8. Typhon 6s
  9. Typhon 3s
Hi all, not new to the RC hobby, but new to Arrma, just got a Talion V3, lovin' it.
Got a question about the dust boots on the V3 Shocks, is the boot really suppose to look like this ?
The boot looks like it's too long and it gets twisted around the shockshaft more and more as you drive, been searching but have not found a good solution. Not a real problem but it doesn't look right ? Has anyone got a fix for this ? Uploading pis of a rear shock.
Looks like they need some air inside around the shaft. There is no possible way for them to twist. They are connected at both ends. Probably not a big deal...
True, they need som air :) If the plastic spacer next to the rod end in the bottom was not there the lenght of the boot would be more correct.
Thinking about removing the spacer but i guess it supposed to act as protector so the shock doesn't bottom out ?
Guess I'll live with it, dabbed some silicone lube on the bottom inside the boot, doesn't twist as much now :)
