Typhon B3RC Racing - Mojavefied M2C Typhon 6S Build
N.VA 703
  1. Kraton 8S
  2. Typhon 6s
Hello All! This is Mike from B3RC Racing here in Northern Va, first time poster long time reader ;)
Wanted to share my Mojavefied M2C Typhon build with everyone and show how it performed.
First Impression: Wow, what a beast this thing is with a wider wheelbase and the Proline Mx28s on it. I was pulling airs and backflips like it was nothing. Super stable over all types of surfaces, super glad I decided to pull the trigger on something that was relatively cheap and an easy swap.
Mojavefied Parts List:
Dif Setup - F/C/R 50/200/20
Front Upper C-Arms: ARA330605
Front Lower C-Arms: ARA330606
Rear Lower C-Arms: ARA330607
Front CVD Driveshafts: ARA310954
Rear Dog Bones: ARA310953
Front Turnbuckles: ARA330602
Rear Turnbuckles: ARA330601
Front Kraton 6s Springs: ARA330507
Rear Kraton 6s Spirngs: ARA330508
Suspension End Caps: ARA330645
Comp Ball Cup Kit: ARA330230
Proline MX28's on F11 Black 17mm Wheels
Rest of the build goes as follows:
Typhon 6s - RTR - Running the High Speed Pinion - Stock Motor and ESC
M2C Chassis - Goliath Chassis - 4mm thick - 7075-T6
M2C Bladderless Shock System
M2C Pillar Ball Retainer Set
M2C Shock Stand Off Kit
M2C Ackerman Bar
M2C Front and Rear Shock Towers - 7075-T6
M2C Front and Rear Braces
M2C Front and Rear(off road) Hinge Pin Set
M2C Droop Screws
TBR Wing Mount
TBR Front and Rear(small version) Bumpers
TBR Rear Mud Guards
Check us out at:
IG: @b3rc2019 - https://www.instagram.com/b3rc2019/
YT: B3RC Racing - https://www.youtube.com/channel/UCeKcewywvrBDA0GQ6HC-IOA?view_as=subscriber
FB: https://www.facebook.com/B3RC-Racing-100447331516792
Thanks!
How much wider is it than a normal truggified Typhon?
So the mojave setup is in between the stock typhon arms and (tuggifed typhon) kraton/outcast arms. Not too wide but not too short.
Plus the mojave arms are like double the thickness of the stock typhon arms. RC DUDE81 has a great video on it. Check it out
wow, I may want to try this. Would this work for 3s? I need to check he parts compatibility, but going wider seems great idea (I don't think the local race people would mind!)
No. To widen the 3S, you can swap to the 4S arms, turnbuckles, driveshafts, hubs, caster blocks, hexes, bearings, and nuts. It’s a long list but it will widen it a little bit.
