iLikeRCs
One of my front driveshafts is bent. Can I drive like this or should I replace it?
Vid that shows how bent it is:
Meh I have driven with worse whilst out and about, but if I was home on the workbench I would straighten it.
It's only adding unwanted vibration that will kill bearings and wear diff outdrives faster the longer you leave it
What's the best way to straighten it? Thinking I could lock it in a vice and hammer it straight?As already mentioned, try straightening it out first.
Either over a block of wood with a hammer if you are feeling more savage, if not, use 3 bolts in a vice. 2 against one jaw, the other in the middle of the 2 on the other jaw. Stick it in with the bend facing the single bolt and tighten it so it bends it straight. Hope my explanation made senseWhat's the best way to straighten it? Thinking I could lock it in a vice and hammer it straight?
That^if not, use 3 bolts in a vice. 2 against one jaw, the other in the middle of the 2 on the other jaw. Stick it in with the bend facing the single bolt and tighten it so it bends it straight.
That^
Thanks, I think i got it pretty straight again now. Another question, when assembling them am I supposed to put grease or something on or just leave them dry?Either over a block of wood with a hammer if you are feeling more savage, if not, use 3 bolts in a vice. 2 against one jaw, the other in the middle of the 2 on the other jaw. Stick it in with the bend facing the single bolt and tighten it so it bends it straight. Hope my explanation made sense
I was going to ask what that looks like and how that works..... need to look into this more
I seriously bought a bench vice just for this purpose.I was going to ask what that looks like and how that works..... need to look into this more
Huh?! Did you get it replaced for free?One of the rear driveshafts on my Kraton 8s EXB roller came bent right out of the box. Albeit, not as bad as your video shows.
No. I probably should've made more of an effort. But I anticipated some pain trying to prove I didn't bend it myself while driving.Huh?! Did you get it replaced for free?
I had one of the first ones, It had 2 bent drive shafts outa the box. The bench vise is an old but proven method.No. I probably should've made more of an effort. But I anticipated some pain trying to prove I didn't bend it myself while driving.
