Ok that's my problem 30 tooth pinion makes it to close what brand spool gear are you running for your pinionwhat gearing and mount are you running? I'm running 39/39 and the stock exb mount on mine and it dropped right into place.
When it goes out that far with stock mount you can't use both screw holes on top is that okOk that's my problem 30 tooth pinion makes it to close what brand spool gear are you running for your pinion
