- Tel Aviv, Israel
- Granite
- Senton 3s
- Talion
- Typhon 6s
- Typhon 3s
- Voltage
Ideally the gears case should be completely closed, but I understand why they had to make the spur stick out like that, without it the spur would need to be few mm higher, and along with it the driveshaft and diffs, all rotating mass that should be as low as possible.
But they could keep it in the same place and have the case wrap it, and do a hole in the chassis where it slides into place, so from below you would see the gear casing being flush with the chassis.
<armchair designer rant off>
