I did this on my Typhon as well but I mounted mine the other way around.
Idk I haven't tried but I am assuming that it needs to be removed firstCan you still remove the motor? Or do you have to remove the ESC every time you pull out the motor?
Your battery lead is so much longer than mine. It's seriously only like 3 inches long.I personally like the esc down in the chassis.. I've been running mine like that since I bought it.. and yes you must remove the esc to remove the power module.. but no big deal, couple screws and flop it over the side of the chassis...
If only you hand those extra 3 inches, Slick! The damage you could do! ?Your battery lead is so much longer than mine. It's seriously only like 3 inches long.
I knew someone would make a penis joke.If only you hand those extra 3 inches, Slick! The damage you could do! ?
You've been getting them all your life? I'm sorry ?I knew someone would make a penis joke.
No I just know how you guys thinkYou've been getting them all your life? I'm sorry ?
I'm just busting balls ?No I just know how you guys think
Is this a typhon 3s? If so where did you get the chassis brace? Did you have to get different diff covers to get it to connect?Your battery lead is so much longer than mine. It's seriously only like 3 inches long.
It was a Typhon 3s, it's the stock brace for the Kraton 4s I bought it off ebay.Is this a typhon 3s? If so where did you get the chassis brace? Did you have to get different diff covers to get it to connect?
Thank you so much!It was a Typhon 3s, it's the stock brace for the Kraton 4s I bought it off ebay.
I'll get you a list of stuff that you will need.
Tower to tower brace https://jennysrc.com/collections/ar...ed-center-brace-240mm-bar-ara320532-ara102690
Center brace pin https://www.arrma-rc.com/part/ARA320529
M2.5 lock nuts https://www.arrma-rc.com/part/AR715008
M3x10mm Cap Head Screws https://www.arrma-rc.com/part/AR723310
Brace mounts https://www.amainhobbies.com/arrma-4s-blx-center-brace-mount-set-ara320528/p967955
Body post set https://www.arrma-rc.com/part/AR320452
Body Mount set https://www.arrma-rc.com/part/AR320453
If you search Jenny's and the kit breakers you usually can get all the stuff for less than buying everything separately plus you get spares of other stuff.
Slick is on it today!It was a Typhon 3s, it's the stock brace for the Kraton 4s I bought it off ebay.
