Alterdcreations
- Felony
- Infraction
- Limitless
- Kraton 8S
This car has been thru a lot of power plants and even more crashes. The carbon chassis held up with but the aluminum end plates have been warped and restraighened as many time as i can remember.
The car with current setup is as follows
castle 1721 28 pinion 36 spur
talion exb 4.3 final drive
xlx2 Qs8
stock spool
carbon drive shafts
flow pack battery tray
scorched carbon chassis with top brace
scorched motor mounts(both 25 and 30mm)
basherqueen carbon strut tower braces.
SRD 4s speed packs
car is pulling just over 400 amps on full pulls . I can gear it a lot more
1st tp5680 1920kv flier(second to last setup…gave away motor and using same esc on another project)
This picture was the first and original setup. On the first 8s pass it smoked the esc and did 147mph(grp s5)
This was the third reliable setup. Did consistant 130’s
This was the same but with a max five first….didn’t last more than two days
This is the current setup with infraction truck body It does 140’s. Frame is twisted so its done for now. I have a new limitless and new chassis. Just waiting on the power plant. It’s a tp 5670 cm 2510kv and a new flier 16s 500amp esc. I will start a new thread .
xlx2 Qs8
stock spool
carbon drive shafts
SRD 4s speed packs
