Infraction Castle 1717/1650 vs Traxxas X01 1717/1650
I believe I heard something once about the castle version being a little less power and runs cooler. Probably done via lower KV than rated?
Pulled this from the web
https://forums.traxxas.com/showthread.php?9091928-traxxas-1717-vs-castle-1717
Pullled 2 interesting lines from that thread above:
"I did open up both a castle 1717 and Traxxas version. Quite different in the part of the rotor that holds the magnets is aluminum on Castle version and plastic on the Traxxas. Same iwith the 1515 versions. Was quite the surprise to me."
"The traxxas has a sealed end at the output end vs the castle with a both ends being removable , motor wires are also different."
