kspitters
Jealous. I’m on break at work. Why are 3/4 taller, if the springs are all the same?I can help as well. Testing out some PETG filament right now.
the 16mm spacer is supposed to go corner where the cord (sorry bad terminology) connects to the bed.Jealous. I’m on break at work. Why are 3/4 taller, if the springs are all the same?
I can try that tonight. Are they apps on iphone
All good. I get it. All I have is apple though. Also, I cant use my printer for any other than idle, it’s broke. I’ll let you know when the warranty parts comeThank you guys!
Good question..
I'm not sure if those Apps are available on iphone...
I gravitated Away from Apple phones, once I found out they like to "Brick" their previous models Just Because Apple Corporate considered/Deemed them to be "OLD" ,via their iOS Updates..
Very insidious & greedy way to force folks out of a perfectly working or upgradeable (more than 2 year old)/"vintage" phone.
sorry for the side rant.
They’re tough to find!Custom 120mm Fan Cover to replace the (NOISEY) Creality PSU's stock 60mm 24V fan And that Very restrictive airflow mount/cover in the Ender 3 S1.
But, Who would have guessed trying to source a decent 120mm Low Profile with hydraulic bearing 24V fan would be such a challenge..
Sorry about that! Quite a bummer. Can you sand/trim the tab at all?I had even designed and printed gaskets for this thing..
Wasted..
That angle looks like it could be tricky with anything even semi brittle. I’m sure you figure it out tho. I’m guessing it doesn’t matter much because you may not print as tall of stuff, but wouldn’t that spot be hard if the extruder is above it?View attachment 295047
Taking some measurements and trying to decide where I want to permanently relocate the filament run-out sensor...
Either at the Rear Right side position of the Z-axis carriage >
Very nice & convenient location.. BUT
Where the filament could be pulled in at an extreme angle when the extruder is all the way to the left...
