Infraction Diff oil stock infraction v2
carlucho
Hi guys, can anyone tell me what is the stock diff oil in this model v2, front- center - rear, because if I like how is going I keep the same setup 😎. Open to any suggestions 👍🏻. By the way, this car is massive 😅
100K center
Front and Rear are 10k.
Make sure u open all three diffs and fill them.. I suspect you have not, hopefully I'm wrong but 9 out of 10 times they will be super low or empty.. and set your droop screws accordingly
😥😥😥 almost seven hundred dollars and they don’t fill properly the diff 🤬 I can take that for the wltoys but not for this price and this brand
Yes I know, you are gonna be heartbroken on a few things, but its ok bro we will get through it!!
One part out a time my fellow basher!! 🤣
There's always gonna be a little sweat and tears in this Hobby. Nothings perfect, but this forum and the awesome people on it will guide you through every step. It's worth it!! 😁✌️
Hahahaahaa I know bro but it’s hard to hear that 😔. You know the number of every diff oil in this car ?
😭 hahahahaha it’s a heartbroken. You know what is the number of every diff oil in this car ?
100K center
Thanks bro
+1
I run stock in my felony, if been contemplating upping it but I think I've just accommodated the driving style off the shelf!!
I use 1mil in the rear and 500k in the front end center is 20mil. On the girlfriend's limitless/infraction.. but all she does is slide around.. but since I speedruns. One is factory. 10k and 10k and the other is 20mil and 20mil. Don't have a center spur. I have a spool.
I just opened mine last night half full at best!
I’m 500k center 60k front and 30k rear. I also tried installing the red aluminum case like the fireteam has as the center diff in the front and it was catching on something I messed with it for and hour. I took it all apart and put the factory “plastic” body and it works perfect. Any explanations?
The lip on the black part of the case hits the GP5 gear, I had to machine mine down with a dremel. I know they advertise it as compatible with the V2 Infraction, but not without customization.
I ran 500k in the center per everone on the internet, but after some experience it results in terrible handling. I went back to the default 100k and it's great now, I might experiment with 150-200k soon.
Um idk, were there any shims on the stock diff gear when you pulled it out!?
Nope.
The front would run smooth then bind up in one spot I messed with it for an hour. Finally switch back just to see only thing different was the case. Works perfect. Now the rear I haven’t touch just the center and front but rear feels like it needs a shim so when I take it out will be interesting to see if there’s one.
