Simon
Hi,
The last two times I have opened the rear differential housing on my Typhon 6s (the outer plastic, not the inner differential) there is dirt inside.
Obviously my concern is that this gets on the gears and causes premature wear.
My first thought was the chassis was bent and I wasn't getting a good seal between the chassis and the diff housing but after the first time it happened, I cleaned it all out and then looked for gaps using a light but couldn't see any.
Now that is has happened again, I am looking for the cause and solutions.
Between the chassis and the diff housing is the only way I could imagine dirt getting in. As a fix, I thought I could buy a sheet of 1mm rubber and cut out a gasket to put between the two.
Does anyone have any other ideas how dirt is getting in?
Has anyone tried making a gasket before?
Thanks,
Simon
Thanks,
Simon
