Rlduling3
I keep popping off the cheap Vorteks Mega shocks. I want upgrades for both my kids' Vorteks. Will Traxxas Rustler shocks fit? Or any tougher suggestions?
Do you have a part number for these shocks? Or a measurement from center to center!I replaced mine with some Traxxas big bore shocks on the front for the same reason. I kept the original Arrma shocks on the back because they seem to damp better (and I never had the back caps pop off).
The replacement on the front was a little bit of a pain due to the bottom side bushings on the traxxas shock being fatter. I fixed this by using a file to widen the slot where the shock screw is. This will make sense when you see it... but the short answer is yes, they will work.
I don't remember if I got "rustlers" or not.... but they are white and the same size as the original Arrma shox.
hope this helps!
PN..... TRA5862Do you have a part number for these shocks? Or a measurement from center to center!
Awesome.... My LHS and I came up with these but they didn't have any in stock to compare to... Didnt want to put out the money to ha e them order them just to "try and see if they fit".... I believe the rears are just a little longer but shouldn't make a difference!...... Thnx for the infoPN..... TRA5862
