Where’d you find those?Can anyone tell how to install these droop screws? I cannot figure out what holds them in. Shouldn't there be threads on the OD that would screw into the a-arms? Am I missing something?
Yeo thanks again something to add to my list for the talion XL rebuild.I used these ones. Kind of fragile though. ordered too many by accident and was glad I did. Already replaced 2. If the dog bone or CVD comes loose it can smash all kinds of things.
https://m2cracing.net/cars-and-trucks/500-m2c-9131-droop-screw-solid-mushroom-head-style.html
Dumb question, which way does it go in? Button hex end on top of arm or the bottom?Yeo thanks again something to add to my list for the talion XL rebuild.
You install it underneath the arm so that the button head contacts the metal tab on the chassis and prevents the arm from going lower.Dumb question, which way does it go in? Button hex end on top of arm or the bottom?
That makes sense, thksYou install it underneath the arm so that the button head contacts the metal tab on the chassis and prevents the arm from going lower.
No problem man. I just figured out how to do them a month ago so it’s fresh on my mind. Ended up spending the 16 bucks for the M2C ones. They can be adjusted from the top because the screw hurt itself is fit for hex. Not sure if it was worth 16 bucks but it’s definitely easier for adjusting. And the button heads don’t have a hex on them so there’s no sharp edges to bite into the chassis tabs.That makes sense, thks
I broke an a-arm on the typhon, have the front end apart. The damage from the original droop screws in much less than I expected. Car is a V3 4+ years old. Been a great car. I will install (arrma ones) tonight because I already bought them. One less thing to worry about.No problem man. I just figured out how to do them a month ago so it’s fresh on my mind. And up spending the 16 bucks for the NTC ones. They can be adjusted from the top because the screw hurt itself is fit for hex. Not sure if it was worth 16 bucks but it’s definitely easier for adjusting. And the button heads don’t have a hex on them so there’s no sharp edges to bite into the chassis tabs.
Love the fact there are a bit taller than the better updated Arrma droops and a bit wider head for the chassis. Those are worth the money swapped all my 6S rigs with those.I used these ones. Kind of fragile though. ordered too many by accident and was glad I did. Already replaced 2. If the dog bone or CVD comes loose it can smash all kinds of things.
And can I now ask the noob question - why do we need them ? What do they do ? And are they important if you use the car as a basher ?Love the fact there are a bit taller than the better updated Arrma droops and a bit wider head for the chassis. Those are worth the money swapped all my 6S rigs with those.
Prevents downwards over extension of the arms. I don’t know if they’re absolutely necessary but it makes sense. I jump my car a lot, not big jumps but just anything I can catch air off in the dirt. The constant overextending downwards of the arms will tax driveshafts and shock bottoms.And can I now ask the noob question - why do we need them ? What do they do ? And are they important if you use the car as a basher ?
thanks
My Man explained it good. here is a video as well. If you have an option for droops and can save the stress off your shock ends, do it. When it comes to cars like my Infraction for drift or speed its needed to dial in the suspension. Infraction needs more than shock tuning, need to dial in the droops based on how you want to perform, drift or speed.And can I now ask the noob question - why do we need them ? What do they do ? And are they important if you use the car as a basher ?
thanks
Yep, I got them for my notorious and will be soon for my Kraton. The ability to adjust them from above is worth the $16 cost.Love the fact there are a bit taller than the better updated Arrma droops and a bit wider head for the chassis. Those are worth the money swapped all my 6S rigs with those.
Finally got round to watching this properly and it really helps explain it, as does a Bars & Tone one I found. However, what this doesn't show is how to actually install new, better droop screws. Im still so new to wrenching on my talion that taking it apart fills me with fear. Ive failed to find any videos that help. Any suggestions ?My Man explained it good. here is a video as well. If you have an option for droops and can save the stress off your shock ends, do it. When it comes to cars like my Infraction for drift or speed its needed to dial in the suspension. Infraction needs more than shock tuning, need to dial in the droops based on how you want to perform, drift or speed.
