dx5 pro launch control
orbens
  1. Felony
  2. Mojave
anyone using this and can help?
need to do a good setup for drag and idk why the acceleration look like that and not linear?
Yeah doesn't look like Launch Control is good at all.
It's far from linear.
But I woudn't place too much credence with the the GPS analyzer.
There are many other factors, like traction when it comes to Drag. This is reflected in that GPS result.
Nm..
I wonder if your peaking on power.. what's the setup
here is the setup:
- limitless v2
- Castle 1721 - 2400KV motor w/ 23t pinion
- Stock spur - 39T
- MMX8S ESC
- 2X CHNL 120C 5600mAh racing 4S LiPo
- Stock Diffs
- Spektrum RC SR6100AT with avc
- BETU servo 55KG 8.4V
- BSR foam wheels (XXPink) no prep
here is the setup:
- limitless v2
- Stock spur - 39T
- MMX8S ESC
- Stock Diffs
Are you sure the MMX8S can handle that motor? Could that be part of the problem here?
You need to get some prep, also the GNSS GeForce is calculated and not measured…
