Hmmm .when I turn the power button on the ESC I don't get any beeps at all.but everything is working fine.i don't ever remember having beeping. Sounds even when my Big Rock was new.ik it should but for some weird reason it don't.i also remember before I changed out my servo my stearing would reset when I turned it on and now it don't but yet it's all working great..very oddThe initialization beep tones of all ESC's is actually generated through the Motor. It doesn't come from the ESC at all. In case you never knew.
Like stated above, the ESC counts out the number of cells based on the packs voltage you are using when you first start it. Normal. Pay attention to this. Then you will hear a final beep with a different tone confirming all is in order. Ready to drive it.
I kinda wished it would.i just like the way it sounds .kinda cool.i bought a castle MM2 combo that I need to get installed so I can go 4s . hopefully that makes them cool beeps.I absolutely believe you.
Has happened with a few old BLX Arrma ESC's. It's actually the ESC causing this IMHO. It works fine, just that the ESC is not sending the Beep tone signals/ fequency to the motor. So you don't hear it. But the ESC still does initialize. It has to, or it won't power up. I used to think it was the motor causing it. But I changed out motors to see, It is just the ESC that is not sending the beep tones to the Motor.
There are a very select few ESC's that actually emit the initialization beeps/tones.
Wow never knew that.i allways assumed there was a micro speaker in the ESC lol.I actually hate the sound. It is rather screetchy to me.Some motors sound different than others. The Motor is the speaker.
If you look closely at the Pinion when it initializes. The pinion actually vibrates with each beep.
Those screws are WAY too long! They should only extend beyond the motor plate by a few millimeters, maybe around 6mm or so.Hi everyone .. it seems the problem starts when I tighten the screws (with the red plate) into the motor and then the motor starts to stutter .. when the motor is in its own it is fine ! It's strange because the red plate does not seem bent .. maybe the screws are to long ? Lol
