I have a stock granite 4x4 blx 3s. Is the ESC that comes on it “good”? Are there better ones? What would be the advantage/if any to upgrading it?
thanks
I am currently at work and I'm just going to talk into my telephone and hopefully it dictates this correct. I don't have your model of rig, but I do have the Senton v3 blx.....I have a stock granite 4x4 blx 3s. Is the ESC that comes on it “good”? Are there better ones? What would be the advantage/if any to upgrading it?
thanks!
Your dictation did very well! I was just wondering what would be the advantages to changing to stock ESC. I plan on running the same 3S batteries. I guess I’m curious if there is anything better about aftermarket ESC’s than the stock.I am currently at work and I'm just going to talk into my telephone and hopefully it dictates this correct. I don't have your model of rig, but I do have the Senton v3 blx.....
first of all I was wondering what you are hoping to accomplish with a different speed control? if you want to go with bigger batteries as in 4s or 6s, yes you will need a different esc, but you may run into difficulties with going with extra power above and beyond what your drivetrain is designed to handle and may cause more problems than it's worth....
If that is not your goal, would reprogramming your current speed control give you the desired results ? look in your owner's manual and it shows you the different programming levels for break, punch, etc. And how to reprogram the esc.
what is the problem with your current speed control? What is your desire in changing it? That would help us understand what you need to do to get you where you need to go.....
If you want it to get higher mph....changing the gearing may be the way....
Sure there are upgrades.....
Since you can reprogram the stock speed control, short answer would be no real benefit , as in noticeable bang for the buck, to get an aftermarket speed control.....IMO.....Your dictation did very well! I was just wondering what would be the advantages to changing to stock ESC. I plan on running the same 3S batteries. I guess I’m curious if there is anything better about aftermarket ESC’s than the stock.
