The beginning of my RC journey stared about 40 years ago with a Tamiya Sand scorcher, Last year decided to buy my eldest an RC for xmas so bought him a Hobao hyper ST (Nitro) not realizing batteries and motors had improved so much over the years, after a big learning curve of jumping into nitro and the normal problems/annoyance and general noise of them I converted it to brushless.. then got the bug haha.
I did some research and watched a shed load of vids and made my mind up to get...an EXB
Then ofc started on the tweeks and upgrades
First thing done was removing standard decals and replacing with custom ones. Screw down body mainly because it's easier to attach imo, Spring loaded wheelie bar installed for obvious reasons
Wheelie Bar:- https://www.aliexpress.com/item/100...earchweb0_0,searchweb201602_,searchweb201603_
Pretty standard electrics at the point of taking these pics HW Max6 1650kv combo with 20t pinion, Radio link RC4GS v2 with telemetry and the R7FG receiver including gyro (so should be good for 600m range)
Transmitter:- https://www.aliexpress.com/item/32809441148.html?spm=2114.13010708.0.0.3a994c4doEOQ8j
Receiver:- https://www.aliexpress.com/item/330...earchweb0_0,searchweb201602_,searchweb201603_
Servo:- SPT5828W-180 28kg 8.4v 0.06s Waterproof High Speed/Voltage
https://www.aliexpress.com/item/1005001877175960.html?spm=a2g0s.9042311.0.0.27424c4dpD6W6o
Once all this was installed and about ready to run it kind of seemed too heavy for the spring rating, so located some big upgraded springs which are more than twice the lb/mm rating of stock. Supplied by Flexo springs
Rear https://www.flexosprings.com/search-products?sku=343732
Front https://www.flexosprings.com/search-products?sku=343728
Following more research into heatsinks/fans found that most need modding to fit or that due to the fins on the can heatsinks might not be the best idea so it got my mind to thinking of an alternative way to mount a fan far enough away from the motor as to not be affected by the motors emf and to not put excess weight directly onto it, so designed the following two brackets to test (going to try the single to start with to see if it's enough)
Fans are from ali express, which are really nice for the price
https://www.aliexpress.com/item/4000726684212.html?spm=a2g0s.9042311.0.0.27424c4dB26kIJ
