- Location
- San Diego, CA
- Fireteam
- Mojave EXB
- Outcast 4s
- Talion EXB
- Typhon 6s
- Typhon TLR
- Vorteks
- Infraction 4x4
So I bought the Fireteam on a whim during the $399 deal. Then I got bored over the break and decided to strip it down and rebuild it from the ground up. Name all the basher upgrades from M2C, Basherqueen, Vitavon, RPM, stainless steel screws, etc., and I'm probably running it, but I'm having problems with power loss. I'm getting intermittent power loss at full speed on a 17t pinion like it's surging. I think it could be a few things...
1. The battery wires are too long
2. I need a bigger ESC
3. I'm getting voltage sag from the battery
4. The wires aren't large enough in diameter (10 gauge) to transfer the power
5. I need to install a capacitor as they use for speed runs
6. My soldering job sucks
Any thoughts?
I am using 5450 mah 6s 120c battery from Max Amps, Castle Connectors, and the MMX 8s. See motor details in the pics:
Here's the motor that I'm using. It's a BEAST. Dimensions: 36 x 101mm with an 8mm shaft @ 2000kv
Top view:
Side view:
Any thoughts?
Top view:
Side view:
