mansour545
- Fazon
Please note!: all issues have been fixed by Arrma support and this post is an experience told no more.
hi guys..
I have bought the Fazon a week ago and had no fun with it since then. First after unboxing it I connected my 6S lipos and tried it in air just ti see how much the tires would balloon, I noticed that all 4 tires are wiggling pretty well and they are out of balance as going faster with throttle it starts to vibrate. In my first run I tried the car and decided to check out the diff brain modes and in a couple of minutes the car started to spin in place without me doing any steering then after closer look I found the rear right drive shaft pin that goes in the U joint is broken!!??
I decided not run at anymore until there is a fix.
I started in changing the 15 tooth pinion gear to the optional 17 tooth pinion that came with. After putting the motor plate in the second position to make a tite but not too tight meshing and did the paper between gears test I assembled it back tried it in air by lifting it by the top handle and gradually pulling the throttle after passing 50% throttle there was a spark and small parts flying out I stopped immediately then after collecting the flying parts it appears to be the spur gear teeth all broken out!!!!!
I contacted support about all the issues just in one week and 2 runs ONLY!! They agreed to replace all tires and rear drive shaft but not the spur gear!!
I did the exact steps in the manual I watched a couple of YouTube videos prior to changing the pinion gear I did the paper test put the motor plate in position 2 from the left as in the picture.. support say that it's from wrongly done gear meshing..
CAN ANYONE TELL ME WHERE DID IT GO WRONG?
I can't express my deepest disappointment and upset about all of that happening in just a couple of runs only.
Anyone from arrma support here who can help!?
I'm so frustrated.
Pics & vids
https://drive.google.com/open?id=0BxV8DT7OUaeiYlV3RVJ2eHFYdG8
hi guys..
I'm so frustrated.
Pics & vids
