Felony ESC and motor combo upgrade.
Dp1felony
  1. Felony
Ordered new fans, but till then removed the old original fans from motor and ESC.
Double sided tape in place for now.
New motor and ESC installed, bind and programmed.
All seems to be working ok. Just needs a proper test drive when wether permits.
You will find that the 160 drops in, it's made for it. Only issue I had was the switch, used double sided tape for that.
Highly suggest putting some tape on the side of the switch, otherwise that button top will eventually pop off, and it will be gone.
Yeah all the holes are already there for it 👌 I managed to fit the switch back in the original position too 👍
