Few pictures of the ebay wheels and tires.
The_Otherside
Huh?
Military Veteran
Appleton, WI
  1. Mojave EXB
They look and handle amazing. All 4 for $55.
Nice, I thought those looked familiar but I couldn't place the wheel. I looks like the tires are HPI copies, even has the same name. Like that wheel though, you got a link or a name ?
Just got mine glued this week and tried them out tonight on my Kraton with 6s.
They worked great, every bit as good or better than the SRC Road Crushers i put on first for comparison value.
https://www.ebay.com/itm/4X-17mm-He...Model-Bigfoot-On-Road-Car-Kforce/153010211389
The seller from my auction, said they may be adding them to a US warehouse so they would be able to ship quicker, mine took almost a month I think to arrive.
TT
Edit, i realize mine has different wheels, and these wheels have a metal insert for the hex, they seem pretty good.
For those of you with the ebay tires, can you post the dimensions (height and width)? I can't seem to find dimensions anywhere on the ebay listings.
Brand:Kforce
Outer Diameter: 139mm
Rim Outer Diameter:113mm
Rim Inner Diameter:103mm
Tyres Wide:70mm
Hex:17mm
They are just slightly smaller than Road Crushers, they drift quite well as they seem to have less grip than Road Crushers.
FYI, Mine were not glued from the seller I bought from, so keep that in mind you may need to glue them.
@TooTall thanks. Do they balloon at 50 MPH? How many hours have you used them for? Is the tread wearing quickly or lasting long? Do you do strictly speed runs or general street bashing (drifting, wheelies, driveway bumps, etc..)?
They don't balloon much. I use them more for street bashing, parking lot bashing.
I ran 2 6S packs thru them the other night on my Talion, power slides, spin outs, drifts, etc, and I couldn't even tell they were worn.
As I mentioned, they seem less "sticky" on the road then the Road Crushers so they spin quit a bit, but still handle nicely.
The Road Crushers, you can see wear after similar runs, actually feathering off the tread, but mine have seen a lot of packs and still have a lot of tread left. I actually bought the ebay ones, thinking the road crushers were going to wear out fast, but they have lasted quite well.
TT
