Talion Fixing Up A Nitro Arrma Talion
etuskoe
For those wondering, this is a production ready unreleased nitro arrma based on the talion platform. No, the engine is not actually an arrma engine. Don't let the logos fool you. It's actually a rebranded Force engine.
Here's some pictures when I received it and with the body I just finished painting up.
Here it is with the body I painted. I tried to make it resemble the v1/v2 bodies.
slick2500
Community Leader
Rapid City, SD
  1. Fireteam
  2. Kraton EXB
  3. Outcast 6s
  4. Senton 3s
  5. Typhon 3s
In the flesh!
One of the guys on Bookface made a Nitro Kraton. In all honesty I would have thought that someone would have made a nitro Typhon or Outcast first as nothing had to be custom made to make them you just need the center section of the Team Durango DNX8.
Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
etuskoe
Last night I tore it apart for a rebuild. I have a scratched spare chassis which I will be using when I run it, hence the rebuild. Here are some pictures I took during the rebuild.
"QC 22"
I'm not sure what this means
I should mention that one of the engine mounts is cracked. This is one of the many reasons why I won't be taking it off jumps or driving it rough in any manner
Here's a look at both of them
And a closeup picture showing the awful quality. Check out that pitting.
Fixed with JB Weld (hopefully)
I have a spare brake and throttle linkage assembly for it. Check out the different brakes & brake pads. I'm assuming everything on this car was all sorted and ready for release except for the brakes and possibly the engine mounts.
Almost finished rebuilding it. Just waiting for the jb weld on the engine mounts to fully cure.
MisterG
Bench Basher
Londonderry, NH USA
  1. Felony
  2. Fireteam
  3. Kraton EXB
  4. Mojave EXB
  5. Notorious
  6. Senton Mega
  7. Talion EXB
  8. Typhon 3s
  9. Typhon Mega
  10. Vendetta
  11. Vorteks
  12. Infraction 4x4
Man that's a sweet rig. Just my .02 here but with the way my Talion likes to roll over and play dead I would definitely be looking into some sort of skid guard to protect the cooling head of that engine.
slick2500
Community Leader
Rapid City, SD
  1. Fireteam
  2. Kraton EXB
  3. Outcast 6s
  4. Senton 3s
  5. Typhon 3s
"QC 22"
Iirc this was just a prototype so that would explain the crappy motor mount and the weird brakes.
Very cool. I didn't realize these ever existed.
1 of 1 iirc.
Garcbomber
God’s Country
Unique! Looking forward to the video. When those crack again from vibration, an experienced aluminum welder will be able to make even stronger than original with re-drilled mounting hole.
Jamhu
  1. Typhon 6s
I never knew such a car existed! I look forward to seeing a video :)
etuskoe
I lowered it a whole bunch so it should be fine.
The engine mounts are made of diecast/zinc. Welding won't work.
