Wow. Great range. I'll have to check the receiver and see if anything is obvious.That's really odd. I have a GT5 (technically it's an Absima CR6P but it's just a rebranded GT5) and never had any reception issues for at least 4-500ft. I'd give the antenna an inspection for any damages, tip sheared off, etc.
I'm sure it can go further than that. At the time I was just kind of limited by the 1000ft road I was running on and never did a proper range test. I've since moved to Futaba but, if memory serves, I'm pretty sure you should be able to get at least 1000ft range out of it if everything is in working order.Wow. Great range. I'll have to check the receiver and see if anything is obvious.
