Good morning, does any body knows how to lower the voltage cut off on the arrma granite 4x4 blx? I bought some new batteries for my new truck and it works well but the truck stops working when the battery is at 3.8 V. If I use the same batteries with my x-maxx they die at 3.35. So the run time in my granite is so short because the voltage cut off is at 3.8 instead of 3.4 or so. How can I fix this? The manual only shows how to change from lipo to NiM.... but not how to lower the cut off voltage.
Also, what's the best way to mount and dismount the battery on the truck. The straps are close to the shaft and there is not much space between the battery on the tray and the shaft. I have to use a thin hook every time. Thanks.
