- Location
- UK..
- Infraction
- Mojave EXB
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 6s
- Thread starter
- #21
All done..??? Slammed Granite V2.0....
I remembered I still had the original Senton chassis so thought I'd use that while I wait for the Jenny's stuff to arrive..
Managed to save the HR mount ? although it now has some battle scars from my vice..?
Put the spare Tactic radio in so no more glitches..??
Tried a different layout as I now have more length, I used the original mount I made earlier and modded it a bit so it would fit inbetween
the motor and receiver box. As one mount tab on the ESC was broken I decided to removed the other one, the mount is screwed down and the ESC is held in place with Sanojtape Acrylic Foam Tape this stuff is super strong but easy to remove..??
The white piece you see is an impact foam block to help not have the same problem with the battery in case of another frontal impact..?
So here it is again in all its glory but even longer this time..??
Won't get to test it till later in the week but hopefully it lasts longer this time..???
Slammed Granite V2.0...???
