Hello all,
I'm starting a thread here to share my Kraton 8S build. I don't plan to do anything extremely crazy, but I want to document what I do with mine and share it with you all.
I plan to stick with spektrum tech for now to utilize the telemetry capabilities. If the power or use of the capabilities is underwhelming I have a max5 combo on standby.
My current setup is stock with a paired Spektrum Rugged radio. I used the spektrum ESC programmer to bump it up to 8.4v and punch to 5. I also disabled AVC. I also run Proline Impulse wheels with their trencher tires.
I have the M2C chassis and motor mount. Spektrum 780Kv motor and 9020 servo. I have the bigger servo box, and 29t spool gear to use as the pinion. I have 20mil and 2.5mil diff fluid on the way, 5mm sway bar for front and rear on backorder. Also have a light kit for it on the way as well.
With the gain in weight I plan to replace the shock fluid with 1000cst instead of 500cst and also order new springs from Arrma rated for 22Ibs/in for the front and rear (they on back order too). That should help it land better without risking bending or breaking the shocks.
I don't plan to do speed records or crazy stuff with it. I just want to get the most out of it and have fun doing it and having a reliable machine. So far this car has been a tank, and I haven't experienced a bent chassis yet. I did bend the center chassis brace when it hit a concrete slap on the windshield though.
I look forward to your responses and your thoughts as I share my experience with you all.
