I would first make sure the batteries are all fully charged and then re-bind the receiver and transmitter.
How to bind your Arrma Granite receiver and transmitter
Press and hold bind button on receiver.
Turn on your Arrma Granite.
Receiver LED will start to blink, indicating the receiver is in bind mode.
Turn on your transmitter, wait a few seconds.
The LED on your receiver will stop blinking and binding should be complete.
Turn everything off and back on again then check range.
If that doesn't work then, since you just bought it yesterday I'd take it back to the hobby shop and have them exchange the ESC or truck. If that doesn't work you can contact Arrma Support.
Both, depends on how fast I want it to run. But I'm new, is this not OK ?
Never mind. thought this was a different post and can't figure out how to delete this.
I had the same thing just happen. When I turned the truck on I never got that long beep to say the ESC was ready. I called Arrma and they said hook the battery up directly to the motor and see if it spins. Well mine didn't so they sending a new motor. He also said make sure ur trims on the remote are all in the middle position.
