So I wanted to check the IR on my batteries because there was a time I charged them all up and let them sit for about 3.5 weeks fully charged and I wanted to know if it damaged them.
What do you guys think of these numbers?
Every charge has been a balance charge and they have been put on storage time every single time before and after that 3.5 weeks.
These batteries are about a year old other than the last two. They are like 6 years old.
I used a Tenergy IR checker to check these and from what I have read the cheap versions usually show the first cell higher than the others which is what I have seen here.
I don’t see any puffing on any of these.
The 2S and 3S batteries run as a pair all the time but the 3S’s run deprecate when I run my Granite but I rotate them.
Lectron Pro 6S 5200mah 50C
8ohm
2ohm
2ohm
2ohm
2ohm
5ohm
Power Hobby 4S 5200mah 50C
8ohm
2ohm
2ohm
6ohm
Lectron Pro 2S 7600mah 75C (Green Stripe)
9ohm
5ohm
Lectron Pro 3S 7600mah 75C (Green Stripe)
5ohm
2ohm
4ohm
9ohm
5ohm
9ohm
2ohm
2ohm
Eflite 3S 1000mah 20C
13ohm
7ohm
7ohm
Kinexis 2S 1000mah 30C
2ohm
19ohm
8ohm
2ohm
2ohm
2ohm
2ohm
5ohm
8ohm
2ohm
2ohm
6ohm
9ohm
5ohm
5ohm
2ohm
4ohm
9ohm
5ohm
9ohm
2ohm
2ohm
13ohm
7ohm
7ohm
2ohm
19ohm
