That will result in a fully tight slipper, which is great for wheelies, but not good for saving driveshafts
This is the guide I used to adjust my slipper clutch... too tight do y'all think?
In theory you might think so, but in reality, just about any floor, any tire condition will get you a fully tight slipper using the tire slip method.Keep in mind that you do this trick on a rough floor, if it’s to slippery it’s to loose.
Exactly. I changed my spur and while the slipper was out I set it at 1 1/2 turns out. Put power module back in and tried the tire slip method on a hard wood floor and it tightened up the slipper almost all the way. Had to loosen it a full turn after that to get it to where I wanted it.That will result in a fully tight slipper, which is great for wheelies, but not good for saving driveshafts
Hope it works out for you. Adjust your slipper as needed. Every setup is different.New driveshaft installed and slipper clutch loosened ~ 1 turn from that tire slip method tightness. Wish me luck! Thank you again for the wisdom, gentlemen
I think a good baseline for me would be drive-more-than-a-few-minutes-without-busting-another-driveshaft. I did not realize a tight slipper could cause that to happen.Yes every slipper is different , you just need a baseline and set it to your liking, not rocket science.
