- Brooksville, FL
- BigRock 4x4
- Kraton 6s
- Nero
- Outcast 6s
Ok now that makes sense. Thanks?Turn on transmitter.
Hold Set button on ESC and turn on, release Set when it starts chirping/red light flashing.
Make sure transmitter is in neutral. Press Set once. One beep/green flash.
Depress throttle on transmitter fully, hold. Then press Set button. Two beeps/2 green flashes.
Reverse/brake on transmitter fully, hold. Press Set button. 3 beeps/3 green flashes.
Turn off ESC. You are ready.
Great help thanks, just to add, if your tx has abs make sure its set to off, my flysky fsgt3c would not calibrate unless the abs setting was set to off.
Hi, I'm new on here and I did all that you explained but when I do the reverse part I get no green light flash or beep is it my remote I could be using? Its the flysky GT3C I'm confused calibrating it.Turn on transmitter.
Or do I have a bad esc i bought it off Amazon.Hi, I'm new on here and I did all that you explained but when I do the reverse part I get no green light flash or beep is it my remote I could be using? Its the flysky GT3C I'm confused calibrating it.
I've tried everything so I'm just requesting a send back i took it out and put it back in the box for a return. Thanks for the info even though it still didn't work and do as it should so I'm not even requesting another one I just want to buy something different and easier to deal with. Hobbywing here i come. ?I doubt it's bad. Bind your Tx to Rx first, you r steering servo should work fine for confirmation. If that is working look for throttle range adjust in your manual for the ESC.
How's that possible the Arrma esc is a Hobbywing esc https://www.arrmaforum.com/threads/esc-rebrand-conversion-guide.9960/Well I see a video on theres and its way more easier than arrma esc to setup. Lol
I must admit when I got into the hobby I read it once and tried it 5 times.read the manual like 5 times and try to program 3 more times then it makes perfect sense...
Yeah but the way I seen specktrum esc setup sounded I can do that one better than arrma esc.How's that possible the Arrma esc is a Hobbywing esc https://www.arrmaforum.com/threads/esc-rebrand-conversion-guide.9960/
Arrma BLX 100 is a rebranded Max10.
Arrma BLX 120 is a rebranded Max10 SCT.
Arrma BLX 185 is a rebranded 8BL150.
Arrma BLX 200 is a rebranded Max8.
They all calibrate the same way.
Spektrum also is a rebranded Hobbywing so again it is the same calibration.Yeah but the way I seen specktrum esc setup sounded I can do that one better than arrma esc.
