The easiest way to do this is to run one 3s battery at a time, plug the loop connector in the other plug. The senton can safely be run on just one 3s battery. Run time will be about 15 minutes or so and the power from one 3s battery is like training mode. Try it and you will see what I mean.New to rc cars so maybe dumb question but need help.What is the easiest way to make senton 6s at least 50% slower. I want my son to play with it but out of the box is way to fast for him . Different batteries maybe ??Please advice.
Thank you.
A very easy way to deal with new people on the throttle is to tape or somehow adhere a chunk of rubber, wood or something to limit the travel of the throttle/trigger. You can customize how much throttle by varying the size of the block behind the trigger. I stick the block to the handle of the radio right behind the trigger. Two sided tape or hot glue should stick firmly and be able to be removed when needed.
I do this with my kids. I just use Velcro, add some behind the trigger to prevent a 'full pull'.
Also, how old is you son?
Another radio can be a great idea.
I have a pair of TS4G radios from Hobbyking. The best two features, Model memory, and Throttle EPA. I have one MM slot set to "Bash" (Throttle to 100%), one to "Race" (Throttle to 80%), and one to "Kid Mode" (Throttle to 30%). This makes it pretty quick and easy to swap profiles and hand the remote to my kids (8 and 9). When it is my turn, I swap back to one of the "Daddy modes".
I know some of the controllers come with a switch on them that will let you dial down the power like I mine it has I believe three positions one is for 50% throttle limit one's 475 and ones for 100% so you can dial it down to 50% throttle
