- Long Island N.Y.
- Infraction
- Kraton 6s
- Typhon 6s
- Typhon 3s
Hi guys anyone know if a company that makes hub extenders for the Typhon 6S...I want it to be a bit wider
On this forum check / search for *truggified typhon. I cant link posts right now but they're available and they work well.Hi guys anyone know if a company that makes hub extenders for the Typhon 6S...I want it to be a bit wider
Only place I could "find" them was Activepowersports, and we all know how that place operates.The ones I use are discontinued as mentioned. Shame really because I like em. I always look back and wish I wouldve picked up more on so many parts....hindsight.
Nonetheless, I bet there's a couple sets out there somewhere...just need to find em.
Also need to use the stock Arrma pins because the ones in the kit are too thick....if you could happen to find some.
https://www.amainhobbies.com/team-associated-rc8t-wheel-hex-set-asc89330/p28097?r=0
Cheap 1/8 17mm hub extenders off e bay.Hi guys anyone know if a company that makes hub extenders for the Typhon 6S...I want it to be a bit wider
Any chance you might be able to lmk if these extenders ended up taking the abuse of some good bash sessions or how they performed? Ide very much appr the info as I'm hesitant spend what IMP is too much $ from JBIRC for a set of four and was thinking of gong with gpm extenders as I can use them with all the 6s rigs/diff length stub axles it seems but nonetheless would really le to know if these even less expensive than the gpm's worked out for you or not...? Thanks in advance manCheap 1/8 17mm hub extenders off ebay.
