I've had some issues as well. The rear diff spur gear had chunks taken out of it, my pinion got chewed up, and i completely snapped a front drive shaft. I was getting frustrated as well. I see all these guys beating the crap out of theirs and mine takes two jumps and it breaks three parts? I'm not blaming the car. Its my lack of experience with 1/8 scale. 1/10 scale i can jump and not break all day long. The 1/8 scale is so much bigger and is harder to judge the landings. So i've taken the advice in this post and i'm running 4s until i can get it right. I'll still run 6s when i'm charging my 4s batteries though.
Same here. My Notorious probably hasn't had 3 packs run through, and last night, I had to tear down the front diff. Found a couple of teeth partially chipped off on the ring gear. It was making a clicking noise when running. Ordered spare diffs, and cleaned out this one, packed it with white lithium grease, and put it back together. Now after all that work, I wish I had just run it till it exploded. Still has a slight click, but will run it until it gets much worse, before I tear into it again. A bit confused about the different diffs. The Notorious has a 10 tooth pinion, and most of the others have a larger pinion. Can't figure how they get a larger pinion in there, with the same case ??? Seems to me as there would not be enough side room ???
Still, how do they fit it in there? Are the gear boxes/bulkheads the same?Only the Senton and Typhon have a bigger diff pinion. The rest are 10t (Noto, Kraton, Outcast, Talion).
It is called "NOTORIOUS". 6s wide open throttle on any terrain is rough on it. I melted thru the plastic center diff carrier case lost my spoiler and disconnected a steering rod all on the same run running road rage street tires on hard top caliche. No flips. No hitting anything. Just wide open throttle. But for me bashing is only fun at full throttle. Youll end up opening ur wallet for sureI'm so frustrated! Seems like every time I fix my notorious, I take it out and break something else. I just did a full teardown, rebuilt the diffs, switched out the A-arms, upgraded some other parts, and I take it out for a run, and mis-judged a turn and hit a curb. Now I have to replace the front differential case and some other suspension parts. Another 30 bucks down the drain! Sometimes I just feel like selling this thing and cutting my losses. I know it is my lack of driving skills, but it still sucks. Just venting...
