I go 0-40 real qiuk,REAL QUIK
@jondilly1974 here we go!
Been busy with RL issues, but I'm back and this time, no limits. Got exactly 2 runs on the Senton rebuild. First time was a noobie mistake with not tightening horn screw, which lead to a specular wipeout. Second was another noobie mistake in not sticking with what im familiar with. The Dumbo may be an great transmitter for bashing but it would seem speed runs are its Kryptonite.
One issue I'm having is with the gnss. I'm using SkyRc GNSS and was wondering what everyone else uses. I see all those graphs etc and notice a lack of that with mine. Or I'm using the wrong app. Any tips here? Even if it's return the SkyRC GNSS for a better one? Half the time, even though I follow all instructions, it doesn't register or save speeds.
By the way, I'm loving the GRPs
In the app hit the Drag button and set it for 0-40mph, then hit Ready. Finish your hit and then hit Read and it will show the graph.
New PB Kraton 6S 25/50/10/43 MMX8S/1717-1260kv HRB 4S 6000mah x 2 GRP 1:5
1.98g !!!!!!!!! I don't
Thats soooo badazzzzzzzz
Damn jd what did you run 1.45 with???????? ThatS-QUIK
Nevermind....found it.ill update top of page tomorrow at work ,slo-day
I’m running the stock electronics........ I can’t get close to those numbers.
You sure you’re not running the Infraction 🤣🤣
You still keen to run an 80mph pass with video footage?
GRP'S HOOK THE BEST COULD THAT IVE FOUND.
Wonder why mine has 2 lines.you guys have 1
The graph on your two runs are totally different .where the runs that way??????
I was running the belted sweeps. She gets outta the hole ok...... just gets loose.
The first hit she hooked up pretty well. Second hit I was on and off the throttle.
I might put the Katars on and do another 0-40 pass.
Are you inputting a distance?
Katars hooked up a little better
This is what I get when I input a distance
My hits were a K6S running 8S on MMX8S/1717-1260kv combo 25/50/10/43 gears GRP 1:5 tires as seen below
I don’t have footage of my 1.450 pass but I did take a quick video after that hit, but my voltage had began to sag a little by then and could only pull a 1.540 I believe. I will upload today and post it here.
I’m going to make that 80mph hit today with the Kraton........... Il have footage attached to that.
What numbers were you getting with the Copperheads on the Kraton?
U gonna hit 80 w copperheads? Have u ever done this? LOL. Can’t wait to see the footage!!
I have hit 74 with Katars.......... blew 3 of them up trying to get to 80 with them.
I was interested to see jondillys 0-40 time with the Copperheads, to compare my time with the Katars.
I’ll be running Sweeps today.
