TwoBelugas
my apologies if someone already used this et up, I don’t come here often so it’s entirely possible I missed it.
As most of you know the limitless has a most annoying limit on the motor length if you want to use both battery trays. So I spent some time on tppower website and found a solution that approches the power of the 4070CM 2200kv but fits in the stock locsirom
to do so you need to build one
https://www.tppowerusa.com/motors/build-your-own/tp-56xx-series/tp-5650
-3Y with 32v limit so 8s is fine even when freshly charged since battery voltage will sag a bit
-more importantly a wye wind so castle 8s or xlx2 don’t burst into flames
-262amp peak, even the MMX8s can handle with with ease
-now the most important part, when you choose v2 body, it is supposed to be 83mm in can length which means...it should fit the stock motor location.
-I ordered the PPS mount with 30mm insert so it will have a chance of fitting.
peak power is 8400w so not far off the 4070cm, but the ability to use two fat 4s batteries in a limitless body(may need to be raised a bit depending on fit) is delicious.
anyway, we will see how it fits when it arrives.
