- Mississauga
- 4x4-Mega
- BigRock 4x4
- Granite
- Typhon 3s
Futaba 4pls and r314.
Have a channel 3 or 4 open and have a spare servo.
Need to fabricate a fixed lower plate and then an upper plate on a hinge that channel 3 tells the servo to go from neutral (closed) to open (other end of servo travel as determined by me with trim for channel 3)
The servo will be mounted horizontal between the diffuser supports and have a pivot ball end link attached to a steering horn and the bottom of the upper plate to push it up and 'open' the rear wing.
The goal: change the balance of the car at will by reducing downforce on the rear end of the car.
The intended effect: reduce drag, ensure there is more downforce on the front end at high speed and reduce the chances of blow overs at high speed. On closing increase rear down force for braking and turning.
