If it’s going sideways, it probably means both rear tires are losing grip. This could be from suspension setup, meaning the camber isn’t adjusted to keep max tire tread contact in turns. By adding some additional negative camber you can get more contact patch in the turn on the outside rear tire.Tried on-road racing with my Arrma Infraction, but every time I try to corner, the Rear-end steps out. How can I fix this? Is it a suspension thing? What's the fix?
Thank you. Will experiment.Start off with diff fluid tuning, and then go from there. Suspension tuning can get tedious because fluid, travel, spring weight, etc all affect how it handles. Diff fluid is pretty straight forward, easy to do, and you'll notice the differences immediately. I suggest purchasing a variety of weights, and then use this chart for general reference. The Infraction has a factory setup of 10k/100k/10kcSt (front, center, rear).
