& the kv why would 9000kv be too high more speed & power right ? Or no ? Sorry im a motor noob
So what less torque? Wouldn't some good wheels traction cancel that out or Would i just be stand still wheel spinning like riding on ice or something? Lol & Does the blx 100 esc support a high kv i think stock is 3200kv what about like 4000kvYou are on the right thinking path. High KV would mean crazy fast speeds... BUT, high KV typically means less torque. You would have almost 3x the KV as the stock motor. You would have to gear it 3x smaller than stock and your temps would still be screaming high..
It would have almost no torque on it, the lower the kv, the higher the torque but less speed and heat. 4000kv is too high and it will overheat.So what less torque? Wouldn't some good wheels traction cancel that out or Would i just be stand still wheel spinning like riding on ice or something? Lol & Does the blx 100 esc support a high kv i think stock is 3200kv what about like 4000kv
What would over heat the esc or motor & what does torque translate to on the rcIt would have almost no torque on it, the lower the kv, the higher the torque but less speed and heat. 4000kv is too high and it will overheat.
The motor would overheat since it can’t support the weight of the RC due to the lack of torque. 4000KV would be perfect in an Arrma Vendetta or Infraction Mega though. I would say that 3500kv and up is for light 2wd 1/10 and smaller, and some 1/8 and all 1/10 touring cars and smaller. You can compensate for the heat by getting a larger can size motor like a 40XX sized.What would over heat the esc or motor & what does torque translate to on the rc
Ohhhh ok now i get it kinda lol yea my senton is heavy with all aluminum upgrades & bs it rips with stock electronics just wanted like 25% more power but yea idkThe motor would overheat since it can’t support the weight of the RC due to the lack of torque. 4000KV would be perfect in an Arrma Vendetta or Infraction Mega though. I would say that 3500kv and up is for light 2wd 1/10 and smaller, and some 1/8 and all 1/10 touring cars and smaller. You can compensate for the heat by getting a larger can size motor like a 40XX sized.
If you are willing to go to 4s, you can get a 130 or 150a ESC and a 4068 motor.Ohhhh ok now i get it kinda lol yea my senton is heavy with all aluminum upgrades & bs it rips with stock electronics just wanted like 25% more power but yea idk
Nope, actually under $200 USD. If JRC restocks this esc, then you can do it for cheap.Yea that's probably what ill have to do down the road but yikes thats goin be like 300$ Lmao
There's a free app on phones called rc gear calculator. Most motor have a max of 50000 rpms.check it out.it'll help ya understand.senton has a 2.85 Trans ratio.Yea that's probably what ill have to do down the road but yikes thats goin be like 300$ Lmao
