The diff caseOpen what up?
How do I remove the bearings & is there any thing needed besides the case and a input gearThe diff case
Do you kno if i need a new diff gasket or can i reuse & what oil is stock 10k diff oilJust work a flat head screwdriver behind the bearing all around. It should eventually wiggle loose. It wouldn't hurt to blast it with brake cleaner or WD-40 to remove some of the grit.
Okay ima try like 20k lolYou can re-use the gasket if you carefully remove it without tearing it. Stock oil is 10k. I used 30k in my Typhon and like it better.
