Stick to the stocks in the rear and the fronts can be RPMWhich RPM arms should I use on my Kraton 8S EXB?
Yup I had to shave off a little bit off where I the shock rod ends go. I just used my knifeNot recommended because of the sway bars and the slightly different shocks on the exb. You will need to get the dremel out. I have not tried it I’m only saying this because it’s the only difference in the two models arms...
The only time I've broken the front arms is during horrible landings (like nose dives and one wheel landings from 20ft plus). I've broken only two controls arms in the front of my Outcast 8s after like what? 50+ jumps.Just broke a front arm on my 8s blx...not happy. Actually I'm BS cause it broke while testing a ramp I just built and I've never jumped jumped any of my RCs ever before. Realizing this is a massive truck, I didn't land bad and was only 4' in the air and now broken. Waaaa waaaaa. Unreal. Thing is 2.5 weeks old and I have 3 sets if packs through it.
This is where it broke on my RTR.
So I'm looking for arms now too.
Well then I'm baffled, since certainly wasn't 20' high, not even 1/4 of that height. Lol. No idea. But ordered the rpm fronts anyway. It popped the front drive shaft as well, but took off the wheel and the ball joint and put it back. I can still drive it, not hard though. Bad jumper I guessYup I had to shave off a little bit off where I the shock rod ends go. I just used my knife
I think it might be quality control or a bad batch of arms, because I've heard of other people just running their 8s Arrma trucks and the arm breaks? So you are not alone. Or taking a very small jump and they break. I've yet to break a rear arm. I've only damaged two of them in the rear of my K8S when the pin broke off and elongated the hole on the arms. I've never even done that on my Outcast 8s, and I've even landed on concrete a few times! While other people break the rear arms like they were glassWell then I'm baffled, since certainly wasn't 20' high, not even 1/4 of that height. Lol. No idea. But orders the rpm fronts anyway. It popped the front drive shaft as well, but tool off the wheel and the ball joint and put it back. I can still drive it, not hard though. Bad jumper I guess
Should I reache out to Arrma and say hello? Or does this forum have Arrma customer service reps as members here? Some sites do.I think it might be quality control or a bad batch of arms, because I've heard of other people just running their 8s Arrma trucks and the arm breaks? So you are not alone. Or taking a very small jump and they break. I've yet to break a rear arm. I've only damaged two of them in the rear of my K8S when the pin broke off and elongated the hole on the arms. I've never even done that on my Outcast 8s, and I've even landed on concrete a few times! While other people break the rear arms like they were glass
I would give them a ring and explain what happened. They'll probably send you a set of arms. Not sure though. I've only contacted them for a couple of thing like a servo and some plastic links. They sent me that stuff with not much questioning.Should I reache out to Arrma and say hello? Or does this forum have Arrma customer service reps as members here? Some sites do.
I'm just diaspointed a guess, haven't even really got a solid feel for the truck yet while I break in a pair of new 4s 9000 batteires.
Had it 3/4 weeks and I don't jump my trucks at all except for this new first time ramp build trail today. Legit less than 4' high impact. Oh well, reminds me of my erevo when I first ran it. Llolol
I'm going to stick to the stock arms since I rarely break them. Plus, you can't use the sway bar. That's been my experience.Which RPM arms should I use on my Kraton 8S EXB?
Just buy some RPM arms for your case. I don't see sway bars.
Already ordered sir.Just buy some RPM arms for your case. I don't see sway bars.
It's funny because I have a brand new new set that I'll probably never end up usingAlready ordered sir.
