jondilly1974
Speed running apprentice, motor Slayer 🤘
- Toledo, OH
- Granite
- Infraction
- Kraton 6s
- Kraton EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
So I shimmed a brand new rear diff last night. Cleaned it all. Dry fit it with as many shims as I could get behind the pins. Cup side took .6mm worth and couldn’t get even another .08mm shim in there. On the gear side I could get .75mm of shims behind the pin. Both sides were firm and couldn’t pull them at all. Neither had resistance. Assembled it dry and it felt good, minimal gear feeling and no notchiness. Opened it back up and put 25k inside. After final assembly it was super smooth yet the outdrive cups were tight. It took one Kyosho shim on the ring gear side bearing. Everything felt like new. Went out and ran one pack with no issues. Half way thru the second pack it started clicking. Now I was bashing pretty fast at the construction site, but no ramp. Lots of donuts and cartwheels. Minimal air.
This was the result:
