Limitless Limitless build "Silent Symphony" updated 02/19/21
Cereal_killer
Bash/Break/Fix/REPEAT 🤣
Hospitality Award
Missouri/Illinois
  1. Limitless
Xlx2 with 1650kv kv motor
SFR carbon fiber brace with 3d printed parts
Basherqueen xlx2 on/off switch
40mm x2 fans
Bittydesign seven65 body along with the infraction parts to swap over
Grp tires "a lot of sets"
Pps mount
Basherqueen Ackerman kit
Arrma Limitless/Infraction/Felony Rc Air Dam Diffuser/Wheel Well Covers USA "Installed
Between waiting for more parts and not really having any time to really build it. Calling it "slowly getting there "
Is that your first rig with using the HR fan brackets? I hope they good, I got the same but without the heatsink, I don't think ima need it.
I use em on my kraton as well. They held up. I don't do extreme bashing with it either though... I have a couple different style housing if it fails though.
I use it with a 40mm Aluminum fan, I hate plastic :D
Skid plates. Aero guards? Bittydesign foam bumper. Arrma front and rear posts.
Have you test fit your lim body with the xlx2 on that brace? I’m only asking because I’m putting mine together and haven’t weighed all my options yet. Looks sweet btw. Here’s mine. Nothing is set in stone yet[. Looks like we’re on the same page. 🤙🏼👍🏼
ATTACH=full]193244[/ATTACH]
Have you test fit your lim body with the xlx2 on that brace? I’m only asking because I’m putting mine together and haven’t weighed all my options yet. Looks sweet btw. Here’s mine. Nothing is set in stone yet[. Looks like we’re on the same page. 🤙🏼👍🏼View attachment 193255ATTACH=full]193244[/ATTACH]
The limitless body fits perfectly with the brace, I've test fitted it before swapping it out. This brace allows you to center the weight. And able to move it to the rear as well. Great quality 👌
That’s SWEET! Thanks for the update! 👍🏼😎😎
What motor are you using for this beauty
Couple more things knocked out, un soldered the 12g to 8g. Shorten the wires. Hooked up the Futaba rx. Mounted 1650kv with 29p to start... going to have to figure a way to get a fan Mounted on the motor.
Looks like it will be a sweet build!
