- Thread starter
- #101
My issue is since I'm pushing the ESC towards its 400amp limit I'd rather have a warrantied one. I don't really trust a DIY repair on something run at max load for several seconds over and over. Kind of lame they're so stand off-ish with anything speed running and just assume we destroy everything we touch. Also annoying because I have to pay for another MMX when I'd like to put this MMX and 1717 in my notorious when I go GT and run an XLX and 1100 castle or XLX and TP 4070 of some sort. Guess I'll have to go full Karen on the new one I receive and bust their balls on any little imperfection I suppose.To be fair to Castle, they don't list any max amp specs for their ESCs (probably for situations like this leaving them a back door). The values we reference are based on real world experience (I've never seen any amp specs on the Castle site...though I might have just been blind and missed it). If you got a link to where they list anything, I'd be curious to see.
Since you're saying that it felt loose from the start, that would indicate a poor connection. Poor connections are going to have a higher electrical resistance as there's not as much material for the pixies to flow through which in turn will result in slightly to much higher temperatures depending on how poor the connection actually is and how many amps you're trying to pull across it. Yeah, that's gonna be aggravating for sure but, I'm sure you can fix it yourself. You got this .
