needbout350
Hey all I just set up a new Kraton 8s exb with max5 esc and hobbystar 980kv geared 29/39 and the esc keeps hitting thermal cut off. It’s set to 125c/257f and when I check the temperature the esc has never been hotter than 130 and the motor is about 160f. I went through the entire drive train no issues found. I tried a dozen mesh settings for the pinion and spur. I tried bigger and smaller pinions and still no change every run ends with thermal cut off. Driving mostly on pavement and outside temp has been 65-85 when testing and driving with mixed throttle. I’m using EC5 connectors with 8000mah batteries. GPS shows top speed of about 55mph. I’ve got 1mill front diff and 500k in the rear the center is the stock 20mil.
A buddy of mine has the exact same setup with 32/39 gears and has no issues. I’ve heard of many people gearing way higher that 29/39 without problems. What am I doing wrong?
