slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Unfortunately sensored won't be a viable option here. All mmx6s and mm2 combos have either 2200kv or their lower kv motors only are reportedly good up to 4s. I only have my small mah 6s packs that I run in my kaiju and the mt410. Same with the max8 g2 (which has questionably reliability anyway from what ive read).
Is it worth the castle esc without the castle motor?
I'm still lost as to why it should be expected that the hobbywing would die in these conditions. Getting warm, yes. Thermal shutdown, sure I would have taken that. But since when does warm or even hot mean automatic spontaneous eruption?
The irony here I guess is that this system would be fine running on 4s. In fact it would be rather average gearing. Everything else the same, going up to 6s should have decreased amperage slightly when used at the same power (which I did). In fact, temps went down.
I'm not entirely convinced it was overgeared, being as temps were in check. Unless we want to assume that hobbywing escs are more likely to spontaneously go up in flames like the spektrum's -- the easiest way I can resolve this in my head is to think I got a lemon. Perhaps somehow a cap was damaged during shipment or something that caused the failure. And perhaps that checks out because this was an rtr version that came in a bag, not a padded box.
The mm2 is much lighter than the max8 and about the same size, but it handled the 4985 just fine....??
I'm not saying that the gearing itself was at fault more that the likelyhood of the retail one dieing would have been the same. You likely got the short straw on the silicone lottery. I've seen a few of the retail ones burst into flames randomly before FWIW.
Yeah the MM2 handled it just fine temps were about the same as the Max6. Like I said I couldn't even tell the difference between the two.
