Modge Podge and Cheap Acrylics Sacrilege?
Jiggs H
Friendswood, TX
So if you've ready any of my posts it's no secret that I'm a budget guy so that means trying to make use of anything I have available around the house - that being said, I've got some questionable decal/sticker ideas and I know a good way to "lock in" decals is with a "clear coat". Can Modge Podge work as a clear coat? I ask becuase, you guessed it, the wife has some with all of her art stuff.
Speaking of my wife's art stuff, she has TONS of colors of acrylic paint (in the little dollar bottles) - when I did model rockets I found out quick that regular spray paint is the way to go, but in RC I don't think the aerodynamics are quite as important, especially since the paint is applied to the under side of bodies - so can cheap acrylics do anything special with bodies? Won't need an answer to this until I paint my first body but still, the question is on my mind!
kspitters
West Michigan
The cheap acrylics can’t bend with a body and, from experience, will crack off at the first slight bend. You should use a polycarbonate spray paint for an rc body. Or, polycarbonate paint in an airbrush. This paint sticks and is flexible.
Here’s one I did. The grey is with polycarbonate spray.
The black was normal paint, from the kid I bought it from. He said he used it as a show body. I ran it, and it turned to the red/yellow one!
Jiggs H
Friendswood, TX
That makes perfect sense - thanks! So regular rustoleum spray paint also won't do the trick then? Don't recall them having anything on the can about being polycarbonate - figured I'd eventually just invest in cans of the Tamiya stuff, I'm sure that stuff is fine right?
Jiggs H
Friendswood, TX
Correct, rustoleum wouldn’t work. The Tamiya “PS-xx” paints are perfect, make sure it’s not anything but PS and then the two numbers. Or, use Traxxas paint, or Duratrax, or I believe Spaz Stix has sprays. Let us know when/if you do one!
Great tips! if I had taken the time to peruse this section of the forum more I probably would have figured that out! Thanks for the quick answers. It's probably going to be quite some time before I do any body work aside from the random spot repair of my Granite BOOST's body lol
kspitters
West Michigan
Sounds good. Almost all info is already here, and not too bad to find with a couple minutes usually. Luckily, most people here are friendly, so there’s no reason not to be helpful. A bit of research goes a long way though.
MisterG
Bench Basher
Londonderry, NH USA
  1. Felony
  2. Fireteam
  3. Kraton EXB
  4. Mojave EXB
  5. Notorious
  6. Senton Mega
  7. Talion EXB
  8. Typhon 3s
  9. Typhon Mega
  10. Vendetta
  11. Vorteks
  12. Infraction 4x4
I've seen videos in the past where some people were using modge podge to apply clippings from magazines and comics to the inside of their shells with excellent results.
real_name_hidden
Bash/Break/Fix/REPEAT 🤣
Hospitality Award
Missouri/Illinois
  1. Limitless
I remember that being a thing back in the late 90s early 2000s.
Answering the original poster.
Nothing that you will buy at Walmart will correctly work for an RC body.
Tamyia PS paint some colors are cheaper than others… but there’s a few that are $15 to $20 per can depending
Traxxas paint…. Cheap enough. Big can is $15
Duratrax paint pretty cheap
Spazstick paint most expensive stuff…
If you’re doing a $50+ body… another 15$ to $35 to do the right way would be cheaper in the long run. Enjoy!
Jiggs H
Friendswood, TX
Great info, thank you!
