Elhish
Just ordered M2c chassis/towers and some other goodies for my V4 Typhon 6s. Do I need to upgrade my motor/esc or original will do with these mods? Advice needed.
Stock electronics will work well for general bashing. I'd try to pick up some fans for the motor and possibly even a better one for the esc, especially if you plan to use a bigger pinion than the one that's on it now. There's some added weight with your upgrades, but the stock combo is still very strong. Why change it if it isn't broken. Future buy, maybe a 4092 can at 1650 to 1900 kv and a Max 6 esc or comparable from a different brand.Just ordered M2c chassis/towers and some other goodies for my V4 Typhon 6s. Do I need to upgrade my motor/esc or original will do with these mods? Advice needed.
Is there enough room to add a fan/heat sink to the motor? (body height is limited)Stock electronics will work well for general bashing. I'd try to pick up some fans for the motor and possibly even a better one for the esc, especially if you plan to use a bigger pinion than the one that's on it now. There's some added weight with your upgrades, but the stock combo is still very strong. Why change it if it isn't broken. Future buy, maybe a 4092 can at 1650 to 1900 kv and a Max 6 esc or comparable from a different brand.
thanks ill check it out!Not sure what pinion gear u r running but a 18-20t an powerhobby twin turbo heatsink & fans,an this 35mm blx185 esc fan and you won't be able to keep tires on it on 6s..20t will wake a stock blx185 up big time.heres one of there hs.
I have two 30 x 30 fans mounted on some cheap heat sinks and they fit under snug. You could also angle them slightly to the outside as there's plenty of room before you get near the body. Some speed runners mount them facing straight out to the side for better air intake.Is there enough room to add a fan/heat sink to the motor? (body height is limited)
