sweeeeeeeeetttttttttttttt , lets see a pretty picture when you get a min , i may even leave it as is for more than 5 mins , well except the chassis and diff of courseGood tae hear it works well @razz007, seein how ah've just put together the same set up!
cheers fella , they are handy , one car does all in my house , having fun sure is the keyThis thread is hilarious to me, being a new yorker with my own funny accent. (sew dey say)
But to see you guys type the way you talk is so funny to me.
Unlimited combinations of different parts to make your own fun beast is one of my main draws to this brand, and having fun is the whole point innit m8? haha
My Krajave is my main girl. My wife often seems jealous the way I work on her sometimes.
Good stuff.
Be the weekend afore ah get it nailed together Razz, what size pinion d'ye run with the backflips? Smallest ah've got is a 16t but d'ye think ah can find it!sweeeeeeeeetttttttttttttt , lets see a pretty picture when you get a min , i may even leave it as is for more than 5 mins , well except the chassis and diff of course
Gord knows fella , I do a grab n go for pinions , I’ll have a snout later n give you a yooo hoooo once the teeth are countedBe the weekend afore ah get it nailed together Razz, what size pinion d'ye run with the backflips? Smallest ah've got is a 16t but d'ye think ah can find it!
Cheers razz, found ma 16t so that'll do for starters, keep an eye on the temps for a bit.How do , I currently running a 12t pinion , but now taken delivery on the EXB talion chassis , located a 16t pinion and have the v5 standard open diff ready too . I have cleaned my bench and will get sorting one lovely evening this coming week
Ohhhhhh that’s pretty , did it last ?Cheers razz, found ma 16t so that'll do for starters, keep an eye on the temps for a bit.
Seen @Velodromed s wee window wi a temp display so might try that, save fannyin aboot wi clips aw day! Finished nailing it together earlier, oot tae smash it up a bit the morra! View attachment 222983
Technically it’s @parcou idea and I borrowed it. Works fantastically!Cheers razz, found ma 16t so that'll do for starters, keep an eye on the temps for a bit.
Didnae get oot Razz, forgot ah'd nae charger, nephew borrowed it at Christmas time and it never came back! He's bringing it over the morra tho!Ohhhhhh that’s pretty , did it last ?
Lol Cheers @parcou! How have yez attached the sensor to the motor can?Technically it’s @parcou idea and I borrowed it. Works fantastically!
I know he used some kind of heat tape on most of his. I used JB Weld steel on mine. But I was about to ask him about the tape also, which one he used and all. Looks less…permanent then the JB.Didnae get oot Razz, forgot ah'd nae charger, nephew borrowed it at Christmas time and it never came back! He's bringing it over the morra tho!
Wonderin if its higher tech than a bit tape!
I used krypton tape, which was recommended here as a good temperature tape. Cleaned the spot on the motor with alcohol and the probe and applied a few pieces of tape. It has held strong from many dirt bashes.Didnae get oot Razz, forgot ah'd nae charger, nephew borrowed it at Christmas time and it never came back! He's bringing it over the morra tho!
